08-27-2018 04:48 AM
Dear experts,
Here is my BR in my second servicenow instance, i wanted to replace the hard coded values(highlighted) of the code, so that , it takes the newly created incident's parameters(like current.short_description, current.impact etc) and transfers that to instance 1
request.setBasicAuth(user,password);
request.setRequestHeader("Accept","application/json");
request.setRequestHeader('Content-Type','application/json');
request.setRequestBody("{\"short_description\":\"created on 24-8-2018\",\"impact\":\"1\",\"urgency\":\"1\",\"description\":\"connected two servicenow instances and trying to pass data\"}");
var response = request.execute();
gs.log(response.getBody());
var responseBody = response.getBody();
var httpStatus = response.getStatusCode();
Integrations
Scripting and Coding
08-27-2018 06:57 AM
BTW, I spent almost the entire session on today's community live stream on this same example. You can find it on YouTube on the Community Live stream 2018-08-27 show.
08-27-2018 04:51 AM
Hi
You can get it from preview script.
Mark correct if it helps.
Omkar Mone
www.dxsherpa.com
08-27-2018 06:57 AM
08-27-2018 08:31 AM
Thank you! I just got lucky to get such a detailed answer.
