How to send notification if state is Pending for more than 3 days
Rameshnathan
Scenario 1
If Ticket status is On Hold state more than 3 days means we need to send 1st notification to user
Scenario 2
If the same ticket status is On Hold state more than 6 days means we need to send 2nd notification to group
The notification days will be change based on the customer so that we are referring customer and days from another table
Ex : ABC customer 1st Notification Day 3 and 2nd Notification Day 6
Ex : XZY customer 1st Notification Day 4 and 2nd Notification Day 5
Please help me how to achieve this
14 REPLIES 14
I would recommend you to use the SLA Workflow to achieve your use case. So that once business time complete automatically send the notification (SLA Workflow monitors only condition met one) and no need to check using schedule job all other incident tasks also.
Don't create new custom table field and Business rule is a expensive work to your instance(Impact performance).
1. Create a SLA Definition
2. Create SLA Workflow using task_sla table and attach workflow to your SLA definition.
Hit Correct/Endoresers/Like/Helpful depending on the impact of the response
@Lakshmaiah Dumpala
Hi Lakshmaiah
Please clarify my doubts,
In this workflow i no need to give company in condition so i will run all the company , that's fine
But the notification duration will change for each company
Ex 1 : ABC company means it will send 1st notification on 3 day and 2nd notification is 6 day
Ex 2: XYZ company means it will send 1st notification on 2 day and 2nd notification is 7 day
How to handle this scenario...?
Dont use SLA, just create your own workflow.. then you can create it exactly how you want it.
Set a timer for 2 days.. when it passed, check if it's company XZY and if that is true, send notification, new timer 1 day, check if it's company ABC and send if that is true etc.
Hi Ramesh,
Dont Create a SLA. As Goran Suggested use Workflow for you incident table. And in that we can check all you conditions.
Let me knnow i can create it for you.
Thank you,
Ashutosh
Hey Ashutosh ,
I do have the same requirement , can you tell me the workflow to be used here.
Thanks.
