12-06-2020 03:29 AM
Hi ,
am using business rule to capture the current work note as below code ,But requirement is when work note updated than only have to capture the work note and send to 3rd party tool .please guide me
current.work_notes.getJournalEntry(1)
Integrations
12-06-2020 05:52 AM
You can have condition in BR
current.work_notes.changes()
To get the latest work notes value use this
12-06-2020 05:44 AM
Hi
Try this
var k = current.work_notes.getJournalEntry(1).match(/\n.*/gm).join("\n");
var grInc = new GlideRecord('sys_journal_field');
grInc.addQuery('element_id',current.sys_id); // Adding filter to find current incident
grInc.addQuery('element','work_notes'); // Adding filter to fetch only Worknotes
grInc.orderByDesc('sys_created_on');
grInc.setLimit(2);
grInc.query();
while(grInc.next() && grInc.value != k)
gs.info(grInc.value);
current.work_notes = 'test ' +grInc.value;
current.update();
12-06-2020 05:52 AM
12-06-2020 06:09 AM
12-06-2020 06:17 AM
I gave you the same syntax in the first reply.
