‎03-03-2020 02:12 PM
Dear Community,
I have an issue with setting Delivery time for catalog items.
On my current project we decided to use Flow Designer for configuring catalog items' flows. I know how to set this value using Workflow Editor like in the below community thread with the answer provided by Chuck Tomasi:
Unfortunately it seems that Flow Designer has a little bit different philosophy. Is there any way to display value from catalog item definition instead?
- 12,299 Views
‎08-09-2022 07:00 AM - edited ‎03-27-2024 04:38 AM
In Flow designer, navigate to the catalog item's flow and select the 3 dots in the top right hand corner and go to 'Flow Stages'.
Add a new stage and name it appropriately (eg 'Fulfillment'), setting the Duration to whatever you want your delivery time to be.
This value will now display in the catalog item form.
Hope this helps.
Edit: Make sure to add this as a stage in the flow also by hovering between actions before clicking the + and selecting the stage
‎04-17-2023 12:20 AM
Is there a way to specify a variable for the time or can I just specify an absolute time there?
‎04-05-2024 07:36 AM
What if I have a single Flow designer for multiple catalog items and each catalog item has a different estimated delivery?
Please comment
‎02-10-2025 05:49 AM
Did you ever find a solution to this?
I also use same flow for multiple items with different delivery dates
‎04-02-2025 07:45 AM
But how can we set a schedule for this ?
‎11-18-2024 05:03 AM
Anything changed? Is there solution for this problem?
