How to synchronize Flow Designer stages with RITM state and handle On Hold transitions
ELMAHDI
Hello everyone,
I have a use case that has been taking me quite some time to implement, and I would appreciate your guidance.
I need to synchronize the graphical stages in Flow Designer with the stages and states of a RITM. I have already created multiple stages in Flow Designer to match the RITM lifecycle. To handle the synchronization, I am currently using Wait for Condition activities to listen for variable or state changes on the RITM and then update the Flow stages accordingly.
However, I must respect the following mapping between RITM state and stage:
• State = Closed Complete → Stage = Complete
• State = Closed Skipped → Stage = Closed Incomplete
• State = Work in Progress → Stage = Delivery
• State = Pending → Stage = On Hold (only when clicking the On Hold UI Action)
• State = Work in Progress → Stage = Assessment (only when clicking the Assess UI Action)
The main issue I am facing is with the On Hold behavior. In Flow Designer, there is no clean way to:
• Go back to a previous stage
• Skip or bypass a stage
• Re-enter a stage once the flow has moved forward
Can someone help me with this i really appreciate your help
@ELMAHDI
Hope you are doing good.
