Is it possible to highlight (red) for check box by Client Script (onSubmit)?
Akkapolk
Giga Expert
function onSubmit() {
	// SetRedBox(cab_required)
Expectation:
ok i got it.
it's true/false type field , it always contains a true or false value so it will always be considered to be filled that's why its showing you as grayed astric mark
for reference. you can inspect on that field and check the value , you will see it has "false" value .
solution is , you can either create here custom field with the choice value "yes" or "no".
Cab Required - yes
                       No
19 REPLIES 19
	if (g_form.getValue('cab_required') === 'true') {
		g_form.addErrorMessage('Unable to close the Change request as there are ' + g_form.getLabelOf('cab_required'));
you were missing g_form.getValue('cab_required')
Thank you. I added it before.
var cab_required = g_form.getValue('cab_required');
I just cut some code for request your suggestion about
It may be look like
g_form.setRedBox('cab_required');
it's working at my end.
how are you exactly testing it.
the code will work , if you checked the check box and try to submit the form then it will show the error message on form.
Yes. It show the error message on top of form but not set red box for the check box.
Expectation:
