Is it possible to schedule reports via email body rather than excel/pdf attachment.
mahesh-gupta
2 ACCEPTED SOLUTIONS
Baala T
Mega Guru
Hi Mahesh,
There is a work-around.
Entire report should be coded in Notification Script using GlideRecord and template.print. This way we can fulfill your requirement.
Few drawbacks also there in it.
- Maintenance would be difficult when there is a need for minor enhancement
- EMail body size will increase
Bala T
SanjivMeher
Mega Patron
As suggested by Bala, notification script can be used to print the table in the email.
In that case you will have to use a Scheduled script to generate the event. And the event should trigger the notification. the notification should use a notification email script to print the data in the email body. As mentioned, it may increase the email body size if the data is too much.
If it is an image, you can specify ${report:png} in the introductory message and set type as Embedded PNG in the Scheduled Report
11 REPLIES 11
Hi @SanjivMeher
Not related to this topic but May I ask what is the use of ${report:include_with}
I tried it but it doesn't seem to work
If you have other reports linked to the current report, it can send those reports as well alongwith the current report.
