12-29-2025 02:10 AM
We have an integration requirement where we will be sending attachments from Incidents to third party application. I am currently doing it using flow designer action.
The main isue that I am facing is the mix of base64 content when multiple attachments are attached to an Incident.
If I am adding a single attachment, it's working absolutely fine. The third party is also able to retrieve and read the attachment. But, the problem is when there are multiple files added , the base64 content gets mixed between the files. Hence, the other integrated environment are not able to read these corrupted files though they are able to retrieve it.
Here's my code -
// ... code ...
inc.addQuery('sys_id',inputs.incident_sysid);
inc.query();
if(inc.next())
outputs.incnumber = inc.number;
outputs.postnumber = inc.correlation_id;
var sa = new GlideSysAttachment();
var gr = new GlideRecord('sys_attachment');
gr.addQuery('sys_id', inputs.attachment_sysid);
gr.addQuery('table_name', 'incident');
gr.setLimit(1);
var attachments = [];
if (gr.next()) {
var bytesInFile = sa.getBytes('incident', inputs.incident_sysid);
var base64string = GlideStringUtil.base64Encode(bytesInFile);
// var base64Content = sa.getBase64Content(gr);
gs.log('base64' +base64string);
attachments.push({
filename : gr.getValue('file_name'),
content_type: gr.getValue('content_type'),
content: base64string
outputs.base64 = JSON.stringify(attachments);
})(inputs, outputs);The file name, content_type are working fine but the content of base64 is giving me the issues.
Any help will be appreciated.
Thanks in Advance !
Nayan
02-19-2026 05:22 AM
Thanks all for your help ! @Ankur Bawiskar , @Dinesh Chilaka
I was finally able to resolve this issue. I learnt that "getBase64Content" is only supported in Scoped application for the flow designer. I have modified my script accordingly, here's my final script .
// ... code ...
inc.query();
if(inc.next())
outputs.zendesknumber = inc.correlation_id;
gr.setLimit(1);
if (gr.next()) {
var gsa = (typeof GlideSysAttachment != 'undefined') ? (new GlideSysAttachment()) : (new Packages.com.glide.ui.SysAttachment());
var attachmentData = gsa.getBytes(gr);
var encData = GlideStringUtil.base64Encode(attachmentData);
attachments.push({
filename: gr.getValue('file_name'),
content: encData
This helped my issue while sending attachments in corrupted file. Every attachment is sent properly with the corresponding File Name, File Extension and the Base64 content.
Nayan
12-29-2025 03:29 AM
@Ankur Bawiskar , if I am using while loop ,it's considering all the attachments on the Incident form.
However, adding a while loop didn't work even with the file name. I am getting the same file name as an output that was added at the very first on the incident form.
12-29-2025 03:32 AM
are you sure you have more than 1 file on that record?
add log and see what's the count
what's returned by subflow? share that json string here
if your subflow output is array of json objects and each object is 1 file data then your logic is correct, 3rd party is unable to handle multiple files
12-29-2025 04:25 AM
@Ankur Bawiskar , yes the row count is showing as 5 , that means the number of attachments on the incident record.
12-29-2025 04:35 AM
then it will run 5 times and there will be 5 objects in that json array
you didn't share your subflow screenshots what came in output?
this output variable base64 in your script step should be of type string
share that variable details as well
try this once
while (gr.next()) {
var bytesInFile = sa.getBytes(gr);
attachments.push({
content: base64string.toString()
12-29-2025 05:37 AM
@Ankur Bawiskar , my subflow output is basically a string that contains the filename, filecontent and file extension.
The filename and file extension is working fine but somewhere the filecontent is getting mixed with other attachment's content leading to the corruption of files.
