Issue with Client Script and Script Include.
JessicaM6884345
We have a multiple-choice variable at the Task level. When the "Yes" option is selected, we want to create a task under the same RITM.
We are using a Client Script and Script Include for this, but while it returns "Task created successfully," no record is actually created. Could you please assist us? Thank you!
 Client Script:
    var getLicenseAvailable = g_form.getValue('license_available');
    if (getLicenseAvailable === 'yes') {
        alert(getLicenseAvailable);
        // Create a GlideAjax object
        var ga = new GlideAjax('EDMS_create_task'); // Name of the Script Include
        ga.addParam('sysparm_name', 'createTask');
        ga.addParam('sysparm_short_description', "Additional task for checkbox selection:");
        ga.addParam('sysparm_description', "Task description goes here");
        ga.getXMLAnswer(function(response) {
            var answer = response;
            alert(answer); // Display the response
Script Include:
var EDMS_create_task = Class.create();
EDMS_create_task.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    createTask: function() {
        var task = new GlideRecord('sc_task');
        task.initialize();
		task.request_item = this.getParameter('sysparm_ritmSysId');
        task.short_description = this.getParameter('sysparm_short_description');
        task.description = this.getParameter('sysparm_description');
        var taskSysId = task.insert(); // Create the new task
        return taskSysId ? "Task created successfully" : "Error creating task"; // Return success or error message
    type: 'EDMS_create_task'
Hello Jessica,
You will need too update the Client script to pass in which table you want to link your record too. the add logic in the script include as follows:
        task.initialize();
		var tableToLink = this.getParameter('sysparm_table');
		if (tableToLink = 'Requested item')
		if (tableToLink == 'Catalog task');
			task.cat_item = this.getParameter('sysparm_ritmSysId');
        // Check if the task was created successfully
        if (taskSysId) {
            // Retrieve the newly created task to get the task number
            task.get(taskSysId);
            return task.number; // Return the task number
            return "Error creating task"; // Return an error message
And in the exisitng client script, change to:
        ga.addParam('sysparm_table', 'Requested item');
In the new client script for linking a catalog item, use:
        ga.addParam('sysparm_table', 'Catalog task');
I'm not sure if you want 2 client scripts or if you can add logic to the existing client script to determine which table you want to link to 'sc_req_item' or 'sc_cat_item'. More details on how you decide is needed. If you want both, then update the client script to call the script include twice, with the code snippet above.
9 REPLIES 9
Hello Jessica,
        task.initialize();
        if (taskSysId) {
Hi @Bert_c1
Thank you for your time and effort in assisting me. I will try both options to gain a better understanding of how they work.
I have one final question: after creating the new task at the "Catalog Task" level, I would like it to redirect to the Requested Item page.
I attempted to use "action.setRedirectURL(current)," but it didn’t work. Do you have any suggestions?
Hi Jessica,
It occurred to me that you may want one task with links to both the 'requested_item' and 'cat_item' fields on 'sc_task'. If so, then add one line to your updated client script:
ga.addParam('sysparm_cat_item', g_form.getValue("cat_tiem"));
and just add one line to your script include
		task.cat_item = this.getParameter('sysparm_cat_item');		// new line
and not the changed I proposed earlier.
As far as redirecting to the sc_req_tiem record, add the following:
	var reqItem = new GlideRecord('sc_req_item);
	if (reqItem.get(this.getParameter('sysparm_ritmSysId'));
		action.setRedirectURL(reqItem);
in the script include, before returning to redirect to the new record.
Good morning @Bert_c1
You are amazing. Thank you
On the redirect, a test using that in a script include failed.  I'm not sure how you would re-direct, create a new post here on that.
