Issue with URL with argument module
lrossy31
Hello everyone,
I have an issue with a module I created on a second sandbox, which is a mailto link on a url with arguments and when I click on it I get the error the page you are looking for could not be found. In the first sandbox the link works but not on the second. Is there a property that has to be set or a setting to get the URL working?
Will greatly appreciate the help.
Luis
All i can suggest is performing an XML export & import and try your new module on the original instance if you haven't already done so. If it doesn't work, it indicates there is an issue with the configuration on the module somewhere. You could also include the XML here so it can be reviewed
A quick google doesn't indicate that mailto links can be disabled for specific URLs via the browser but this could be a cause if possible. I'm not aware of any properties that would impact this, although it shouldn't be too difficult to track what properties have been modified on the first sandbox by looking at the sys_properties list and sorted on updated. My PDI allowed them to work without having to update any system properties
