Jira Integration : Connection Alias field not showing up in Flow Designer Action - Create Issue ?
indyguy
I am trying integrate JIRA in my ServiceNow PDI.  I have created Credentials, Connection and credentials  as shown below
In flow-designer, when I create Create Issue Action,  I do not see Connection Alias field. Can someone help me in this. I have seen similar issues being asked in the community, could not find the solution. Any idea ?
svani
Hi @indyguy ,
did you resolved the issue, i am facing the same issue,let me know if you resolved .
thanks in advance
god father
i am also facing same issue, can you please provide the solution if its resolved!
I have the same issue.
 if you find any solution, please guide me .
bekfro
The connection part in Flow Designer is old, and will no longer be required, as long as you see the connection in Flow Designer connections you should be good:
One more note is you will have to save the flow before the projects populate
