Load Data CSV doesn't load anything properly
Dameli Utembaye
Hi I am trying to upload a prety big CSV file -- this is what I am seeing instead of the data. I followed the steps on the forum. Is there a better way to somehow read data from CSV? Or how do I resolve this? My csv is valid, I followed one of the troubleshooting articles and it mentioned that the issue could be in the invalidity of the CSV, I checked here:https://csvlint.io/validation/65772eb86755e60002000041 its fine Image 12-11-23 at 7.56 AM.jpeg
Looking at the tutorial and it looks like this is to import data to an existing table -- what if I want to create a new table and populate that with the spreadsheet information
Hi @Dameli Utembaye
For Import (Load Data) - Use can use existing table (if fulfil your requirement) else create new Import Set.
For transform,
You can map it with OOTB tables or custom tables (Custom table) must be created.
