Make reference variable dependant on another reference variable
SN_BUDDY
I have an "Account" variable (reference field) to customer_account table and i have a "Site" variable (reference field) to cmn_location table. The "Site" variable sits in a MRVS. When account is selected and i click into the MRVS and select "Site" i should only see sites relating to the account.
The relationship is, there is an account field within the location table which captures the account.
I thought this would be simple with Ref qualifier and variable attributes but cannot get it to work
Its sorted. Managed to populate the account field from the below script
function onLoad() {
	//populates the Account_capture variable with the Account variable selected.
g_form.setValue('account_new', g_service_catalog.parent.getValue('account'));
Hi @BharathChintala appreciate the script but would you mind explaining what the they do? Im a bit confused by the first one and not sure where to put the account_new (which is within the MRVS) and the account variable which is outside the MRSV.
Thanks.
That has not worked unfortunately. Below is what was done.
1. Create Client script on catalog item for onChange and onLoad
onChange
   if (typeof(Storage) !== "undefined") {
sessionStorage.setItem("account", "" + g_form.getValue('account'));
alert("Sorry, your browser does not support Web Storage...");
onLoad
function onLoad() {
Check the "Account" value
Update "Parent account" with "Account, Parent account" value
I then created an onLoad client script within MRVS
function onLoad() {
  var account = sessionStorage.getItem("account");
g_form.setValue('account', account);
And then set the ref qual for the site variable to the below.
javascript:"site="+current.variables.account_new
Nothing has worked but your help is much appreciated
