Metric definition defined but not creating metric instances for sys_updated_by field
Ravi Gupta1
Metric definition defined but not creating metric instances for sys_updated_by field.
Any suggestion, how to achieve it.
@Ravi Gupta1
ServiceNow doesn't monitor OOTB system fields (sys_created_by, sys_updated_by) so metric instances won't trigger unless you add custom logic
use this script in the Metric definition
createMetric(current.sys_updated_by.toString());
function createMetric(value) {
    var mi = new MetricInstance(definition, current);
    var gr = mi.getNewRecord();
    gr.field_value = value;
    gr.calculation_complete = true;
    gr.insert();
then have after update business rule on incident table to trigger metric.update event
this will fire the event every time the record is updated allowing your metric definition to create desired metric instances
    gs.eventQueue('metric.update', current, '[sys_updated_by]', 1, 'metric_update');
})(current, previous);
Dr Atul - LNG
Hi @Ravi Gupta1
Is this table a task-based table? If not, then metrics will not work.
Hi Atul,
Table which I am using is task based. I am able to create metric instance for other fields but not for sys field for same table.
Ravi
Thanks @Ravi Gupta1 . Could you please try this in the Incident table as an example? Create a new record, then update it and check if the capture is happening or not.
