10-27-2025 04:54 AM
I am working on a ServiceNow catalog item where I need to display a dropdown field with multi-column values (e.g., Name, Role, Location)
- I don't want to use a reference field.
- I don’t have the values stored in any table, nor do I want to create a new table just for this.
- The values are static and known ahead of time
A dropdown that shows something like:
John Doe | Developer | Hyderabad
Jane Smith | Analyst | Pune
Any suggestions, code snippets, or pointers to existing community posts or documentation would be greatly appreciated!
Thanks in advance!
10-27-2025 09:52 AM
If you don't want the data to be in a custom table, then I don't know of any way to get a selection to show different columns as you described.
10-27-2025 04:56 AM
You can use the MRVS concept in ServiceNow at the catalog item level. You can also reference user name and location if needed. These are all variables only.
10-27-2025 09:51 AM
MRVS concept will make the columns values as independent of each other which below to single record
i want the columns to be part of one record.
MRVS concept will result selecting value 1 from column A and value 2 from column B
I need only to map the Value 1 from column A to Value 2 from column B it should be as single row values
10-27-2025 05:03 AM
It wouldn't be columns, but you could use a regular Select Box and make the display values and internal values like this:
Display Value: John Doe | Developer | Hyderabad
Internal Value: Jon Doe
Display Value: Jane Smith | Analyst | Pune
Internal Value: Jane Smith
10-27-2025 09:49 AM
I don't want it to display as single text it should be display as different columns
any alternative approach please suggest
