My PDI needs to be retired for a technical issue that I am not aware of? Random Technical Issue PDI
Danielle10
Good day!
I received this email from the ServiceNow Developer Program about my PDI. My PDI is vital for me and everything in it that I have worked so hard to do, and I do not want to lose it.
I am not sure why it says that I have technical issues. Why can't they offer help to fix it and tell me what is wrong with it instead of asking me to retire it when I need it? Would someone help me with this I am not able to get help from ServiceNow about this issue.
Thank you!
This is the email that I received:
Dear Service Now Developer,
Please save your work and release the current instance by the end of next week. The instance has technical issues and must be retired.
Thanks for being an active member of the ServiceNow Developer Program.
Best Regards,
ServiceNow Developer Team
© 2024 ServiceNow, Inc. All rights reserved.
Dr Atul G- LNG
Hi @Danielle10
Consider this email as Fact and take the back up Asap.
https://youtu.be/TT_sE0QpzEE?si=fONuEv2ZcaF8UcFI
Here is Robert view.
9 REPLIES 9
Hi @Danielle10
Current situation in PDI is not good,so tough to commit any thing. even I heard few users get the new pdi and when they open the new PDI , it redirect to old PDI only. So better to take back up and release.
AndersBGS
Hi @Danielle10 ,
Several persons (including myself) have received this email, hence this is exactly why you should always backup your work. Either to a repository for scoped application or export to update sets under development.
best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
Good day!
Do you know if this is still true? Once you release your instance, there is a restore instance button that you can do? Look at this link. Please and thank you. I am trying to not lose everything in my PDI... Having a hard time because I am not a developer.
https://developer.servicenow.com/blog.do?p=/post/restore-pdi/
Dr Atul G- LNG
Hi @Danielle10
Backing up every thing is not possible and it is very time consuming.
Identified what is important for you.
Make a list
Avoid Data Backup (if not required)
Move in update set (mainly reports / dashabords)
Dr Atul G- LNG
Hi @Danielle10 \
Navigate to the records you want to add to the update set and click Add to Update Set under Related Links. Since Dashboards and Reports are using custom UI's you will need to navigate to the record directly via the Filter Navigator: Performance Analytics Dashboards: enter pa_dashboards. list and hit enter.
https://www.servicenow.com/community/performance-analytics-blog/migrating-dashboards-and-reports-via...
