09-08-2025 07:15 AM
I am working on a catalog item where the user can select either an Incident or a Change Request ticket using catalog variables.
Requirement:
If the user selects an Incident, the Configuration Item field from that Incident should automatically populate in the catalog item’s configuration_item variable.
Similarly, if the user selects a Change Request, the Configuration Item from that Change should populate in the same configuration_item variable.
variables:
please_select_the_inc_ticket → reference to Incident table
please_select_the_chg_ticket → reference to Change Request table
configuration_item → reference to cmdb_ci
Thanks in advance 🙏
09-08-2025 08:17 AM
Hi @tilekarnilesh ,
You do it by calling a script include or using getReference in onChange client script.
Here I have explained using getReference method, so you don't need to write script include.
Create two onChange client script on inc ticket and chg ticket varibles.
1)Inc Ticket
if (isLoading) return;
// Clear CI when cleared
if (!newValue) {
g_form.clearValue('configuration_item');
// Get selected Incident’s CI
g_form.getReference('please_select_the_inc_ticket', function(incident) {
if (!incident) return;
// Incident’s CI fields. Usually 'cmdb_ci' is the field on incident.
var ciSysId = incident.cmdb_ci; // sys_id
var ciName = incident.cmdb_ci.getDisplayValue
? incident.cmdb_ci.getDisplayValue()
: ''; // display name if available
if (ciSysId) {
// Provide both sys_id and display value to avoid extra round-trip
g_form.setValue('configuration_item', ciSysId, ciName);
2)Chg Ticket
if (!newValue) {
// Get selected Change Request’s CI
g_form.getReference('please_select_the_chg_ticket', function(chg) {
if (!chg) return;
// Common Change fields are 'cmdb_ci' on change_request (or 'ci' on older/custom)
var ciSysId = chg.cmdb_ci || chg.ci; // adapt if your field is named differently
var ciName = '';
// In many cases, getReference returns properties as strings; try display value fetch
if (chg.cmdb_ci && chg.cmdb_ci.getDisplayValue)
ciName = chg.cmdb_ci.getDisplayValue();
if (ciSysId) {
If both selectors are visible, add logic to clear the other field on change to avoid confusion, or make them mutually exclusive with UI Policy. For example, when Incident changes, clear please_select_the_chg_ticket, and vice versa.
If you want to use script include refer below
Auto populate catalog item field from client script
Bhimashankar H
If my response points you in the right directions, please consider marking it as 'Helpful' & 'Correct'. Thanks!
11-10-2025 07:50 AM
Hope you are doing good.
