Need help in client script
nameisnani
Hi Team
can any one please help me , in this request
Based on the type of request ,  Infrasturure request should populate .
can any one please provide me script for this .
12 REPLIES 12
nameisnani
It's bit confused , could you please provide script
Hi @nameisnani ServiceNow is all about Best Practice. I would suggest you to always prefer OOTB solution if possible. I'm sure you will get more complex requirement than this in future. So confusion cannot be the reason to not implementing the OOTB solution.
Cheers!!!
Arya123
Hi @nameisnani ,
You can use Catalog OnChange Client Script
Select the type : Onchange
Select the Variable Name: type_of_request// use you backend value
 var type = g_form.getValue('type_of_request');
 if (type == 'mainframe')//use the backend value of the Knydrnl Mainframe
    g_form.removeOption('infra','storage_backup');//replace with your backend vale of Infrastructure request and Storage & BackUp
 else
    g_form.addOption('infra','storage_backup','Storage & BackUp');
//add g_form.removeOption and g_form.addOption for other Choice aslo
I think this a good template to follow. Although you don't need a variable for type. The "newValue" contains the value for type of request so it become redundant to call it twice.
nameisnani
@Arya123
your script is not working
