Need help in client script
nameisnani
Hi Team
can any one please help me , in this request
Based on the type of request ,  Infrasturure request should populate .
can any one please provide me script for this .
12 REPLIES 12
hi @nameisnani ,
please correct your code you need to give
g_form.removeOption('infrastruture',shared_floder')
g_form.removeOption('infrastruture',storage_backup')
g_form.removeOption('infrastruture',patch_management);
//like this you need to give one by one for each choice for removing and adding
g_form.addOption('infrastucture',"backend value', ' NAME OF THE CHOICE')//These these are for one choice
Hello @nameisnani
Could you please try the below sample script for onchange catalog client script:
(function() {
// Define the mapping between "Type of Request" and "Infrastructure Request"
var typeToInfrastructureMapping = {
"Network": "Network Setup",
"Hardware": "Hardware Installation",
"Software": "Software Installation",
"Security": "Security Configuration"
// Get the value of the "Type of Request" field
g_form.getControl('type_of_request').onchange = function() {
var typeOfRequest = g_form.getValue('type_of_request');
// Check if the value exists in the mapping
if (typeToInfrastructureMapping[typeOfRequest]) {
// Set the "Infrastructure Request" field value based on the mapping
g_form.setValue('infrastructure_request', typeToInfrastructureMapping[typeOfRequest]);
// Clear the "Infrastructure Request" field if no match is found
g_form.setValue('infrastructure_request', '');
Priya Biradar
Hi @nameisnani
Please use this client script
    var typeReq = g_form.getValue('type_of_request');
    if (typeReq == 'aws') {
        g_form.clearOptions('infrastructure_request');
        g_form.addOption('infrastructure_request', 'none1', 'None');
        g_form.addOption('infrastructure_request', 'request_for_information1', 'Request for Information');
        g_form.addOption('infrastructure_request', 'audit_enquiries1', 'Audit Enquiries');
        g_form.addOption('infrastructure_request', 'data_extract1', 'Data Extract');
        g_form.addOption('infrastructure_request', 'infrastructure_design_enquiries1', 'Infrastructure Design Enquiries');
        g_form.addOption('infrastructure_request', 'shared_folder_access1', 'Shared Folder access');
        g_form.addOption('infrastructure_request', 'storage_and_backup1', 'Storage & Backup');
        g_form.addOption('infrastructure_request', 'patch_management1', 'Patch Management');
    } else if (typeReq == 'kyndryl_mainframe') {
        g_form.addOption('infrastructure_request', 'none', 'None');
        g_form.addOption('infrastructure_request', 'request_for_information', 'Request for Information');
        g_form.addOption('infrastructure_request', 'audit_enquiries', 'Audit Enquiries');
        g_form.addOption('infrastructure_request', 'data_extract', 'Data Extract');
        g_form.addOption('infrastructure_request', 'infrastructure_design_enquiries', 'Infrastructure Design Enquiries');
        // g_form.clearOptions('infrastructure_request');
