Need help in the flow
‎04-22-2025 05:01 AM
Hello Team,
I have created a flow to remove access requests for leavers. However, the current behavior creates multiple catalog tasks for the same catalog item. Ideally, I want only one task per catalog item to remove access. For example, if a user has 5 ServiceNow access requests and leaves the company, there should be just one task generated to remove all ServiceNow access.
Output:
‎04-23-2025 12:53 AM
@Ankur Bawiskar :However, I want the catalog task to be assigned based on the support group of each item. How can we handle this scenario?
‎04-23-2025 01:41 AM
in this case since each item will have different support group then how it will be handled when 1 catalog task is created?
‎04-22-2025 05:55 AM
@AparnaUttaG What are you doing at step no 12 for each requested item record?
‎04-23-2025 12:36 AM
@SANDEEP28 : Step 12 was created to ensure the RITM is closed once all tasks are completed.
