Need help on adding Glyph icon
shaik_irfan
On the Service Portal i want to add my own custom glyph. Can anyone please help me how to do this
@shaik.irfan
Set the CSS to of the outer div containing the image to this
    background: #1F8476;
    display: inline-block;
    border-radius: 100%;
    width: 50px;
    height: 50px;
    object-fit: contain;
    padding: 10px;
and set the image css to this
height: 100%;
filter: brightness(0) invert(1);
Note: You don't need to apply filter. I just did that to make it white. You can just upload a white Image.
Here is the output
20 REPLIES 20
I gone through that Ankur, i dont see any valid info in that
Below is my script:
Image icon container is custom
<div class="iconlink" ng-class="{'high-contrast': accessibilityModeEnabled}">
  <!--// Top Icon -->
  <a ng-if="::(options.link_template == 'Top Icon' || !options.link_template)" ng-href="{{::data.href}}" class="top_icon {{::options.class_name}}" target="{{::data.target}}">
    <div class="m-b fa fa-{{::options.glyph}} fa-4x {{::options.class_name}} text-{{::options.color}}"></div>
    <h2>{{::options.title}}</h2>
    <span class="text-muted">{{::options.short_description}}</span>
  </a>
  <!--// Circle Icon -->
  <a ng-if="::(options.link_template == 'Circle Icon')" ng-href="{{::data.href}}" class="circle_icon {{::options.class_name}} text-{{::options.color}}" target="{{::data.target}}">
    <span class="fa fa-stack fa-2x">
      <i class="fa fa-circle fa-stack-2x"></i>
      <i class="fa fa-{{::options.glyph}} fa-stack-1x fa-inverse"></i>
    </span>
  </a>
   <!--// Image Icon -->
  <a ng-if="::(options.link_template == 'Image Icon')" ng-href="{{::data.href}}" class="image_icon {{::options.class_name}} text-{{::options.color}}" target="{{::data.target}}">
         <img  src="{{data.target}}" alt=""/>
        </span>
   </a>
  <!--// Color Box -->
  <a ng-if="::(options.link_template == 'Color Box')" ng-href="{{::data.href}}" class="color_box {{::options.class_name}} icon-link-background-{{::options.color}} text-white" target="{{::data.target}}">
    <div class="fa fa-{{::options.glyph}} fa-3x {{::options.class_name}}"></div>
    <span>{{::options.short_description}}</span>
  </a>
</div>
Image circle is custom:
.iconlink a label,h2 {
  display: block;
  font-size: 2.5rem;
  font-weight: 300;
  line-height: 1.1;
  padding: 0;
  margin: 0 0 10px 0;
/* TOP ICON ---------- */
a.top_icon {
  display: block;
  padding: 20px;
  text-align: center;
a.top_icon .fa {
  display: block;
  text-align: center;
/* CIRCLE ICON ---------- */
a.circle_icon {
  display: block;
  padding: 20px 0px 20px 70px;
  position: relative;
a.circle_icon .fa {
  position:absolute;
  left: 0px;
  top: 10px;
/* Image Circle ------- */
a.image_icon {
  display: block;
  position: relative;
a.image_icon .fa {
  position:absolute;
  left: 0px;
  top: 10px;
/* COLOR BOX ---------- */
a.color_box {
  display: block;
  position: relative;
  padding: 20px 20px 20px 82px;
  border-radius: 4px;
  margin-bottom: 20px;
a.color_box .fa {
  position:absolute;
  left: 20px;
  top: 20px;
  width:42px;
  text-align: center;
.icon-link-background-primary {
  background-color: $brand-primary;
.icon-link-background-info {
  background-color: $brand-info;
.icon-link-background-success {
  background-color: $brand-success;
.icon-link-background-warning {
  background-color: $brand-warning;
.icon-link-background-danger {
  background-color: $brand-danger;
.icon-link-background-default {
.text-primary {
  &:hover {
    color: darken($brand-primary, 20%);
.text-info {
  color: $brand-info;
  &:hover {
    color: darken($brand-info, 20%);
.text-success {
  &:hover {
    color: darken($brand-success, 20%);
.text-warning {
  &:hover {
    color: darken($brand-warning, 20%);
.text-danger {
  &:hover {
    color: darken($brand-danger, 20%);
.text-default {
  &:hover {
.high-contrast {
  .text-primary {
    color: darken($brand-primary, 10%);
  .text-info {
    color: darken($brand-info, 10%);
  .text-success {
    color: darken($brand-success, 10%);
  .text-warning {
    color: darken($brand-warning, 10%);
  .text-danger {
    color: darken($brand-danger, 10%);
  .text-default {
Server:
(function(){
    var gr = $sp.getInstanceRecord();
	data.href = $sp.getMenuHREF(gr);
	data.target = options.target || "";
	var img = new GlideRecord('db_image');
    img.addQuery('sys_id', options.image);
    img.query();
    if (img.next()) {
      data.target = img.getValue('name');
Option Schema:
[{"name":"link_template","section":"Presentation","label":"Template","type":"choice","choices":[{"label":"Top Icon","value":"Top Icon"},{"label":"Circle Icon","value":"Circle Icon"},{"label":"Color Box","value":"Color Box"},{"label":"Image Icon","value":"Image Icon"}]},{"name":"image","section":"other","label":"Image","type":"reference","value":"db_image","ed":{"reference":"db_image"}}]
Do i need add anything else ?
Hi Shaik,
You set the image source as data.target. In the server that is set to options.target. But in the options I don't see a target.
Can you try adding it.
Or set it in Server code like this:
Change 'indicator-incident.svg' to your image.
data.target = "indicator-incident.svg";
Assuming you uploaded the image to the ServiceNow images table (db_image).
@Willem
I am able to get the image as icon now but it is not setting as circle box
Here is my final code
HTML:
  <!--// Top Icon -->
  </a>
    </span>
  </a>
         <img src="{{data.target}}"/>
        </span>
   </a>
  </a>
</div>
CSS:
  display: block;
  font-size: 2.5rem;
  font-weight: 300;
  line-height: 1.1;
  padding: 0;
  margin: 0 0 10px 0;
a.top_icon {
  display: block;
  padding: 20px;
  text-align: center;
a.top_icon .fa {
  display: block;
  text-align: center;
a.circle_icon {
  display: block;
  position: relative;
a.circle_icon .fa {
  position:absolute;
  left: 0px;
  top: 10px;
a.image_icon {
  display: block;
  position: relative;
a.image_icon .fa {
  position:absolute;
  left: 0px;
  top: 10px;
a.color_box {
  display: block;
  position: relative;
  border-radius: 4px;
a.color_box .fa {
  position:absolute;
  left: 20px;
  top: 20px;
  width:42px;
  text-align: center;
.text-primary {
  &:hover {
.text-info {
  color: $brand-info;
  &:hover {
.text-success {
  &:hover {
.text-warning {
  &:hover {
.text-danger {
  &:hover {
.text-default {
  &:hover {
.high-contrast {
  .text-primary {
  .text-info {
  .text-success {
  .text-warning {
  .text-danger {
  .text-default {
Server:
(function(){
    img.query();
    if (img.next()) {
Object Schema:
Please let me know, how to get it same as oob circle icons.
Note: My code is Image Icon in HTML, and Image circle in css
You need to set a border radius:
Either in px (4px like the others)
a.image_icon {
    display: block;
    border-radius: 4px;
    position: relative;
  a.image_icon .fa {
    position:absolute;
    left: 0px;
    top: 10px;
Or percentage:
a.image_icon {
    display: block;
    border-radius: 50%;
    position: relative;
  a.image_icon .fa {
    position:absolute;
    left: 0px;
    top: 10px;
@Willem
No sir, still its same
