Need help on adding Glyph icon
shaik_irfan
On the Service Portal i want to add my own custom glyph. Can anyone please help me how to do this
@shaik.irfan
Set the CSS to of the outer div containing the image to this
    background: #1F8476;
    display: inline-block;
    border-radius: 100%;
    width: 50px;
    height: 50px;
    object-fit: contain;
    padding: 10px;
and set the image css to this
height: 100%;
filter: brightness(0) invert(1);
Note: You don't need to apply filter. I just did that to make it white. You can just upload a white Image.
Here is the output
20 REPLIES 20
Can you add this to your CSS:
img {
  border-radius: 50%;
If that works, might be best to give your <img> an id value and set it that way.
No sir, it didnt worked. Can you please look at the instance sir ?
@shaik.irfan
    width: 50px;
    height: 50px;
    padding: 10px;
height: 100%;
Here is the output
@serviceportalpro
Sir,
If you dont mind can you please look at my instance. I did not understand what you mean outer div ?
My Image icon html code dont have any div 😞
Looks like you have a span that wraps the image in one of your widgets. It should work the same way.
Ritesh
Intellective
Bringing WOW on NOW
