Need help on adding Glyph icon
shaik_irfan
On the Service Portal i want to add my own custom glyph. Can anyone please help me how to do this
@shaik.irfan
Set the CSS to of the outer div containing the image to this
    background: #1F8476;
    display: inline-block;
    border-radius: 100%;
    width: 50px;
    height: 50px;
    object-fit: contain;
    padding: 10px;
and set the image css to this
height: 100%;
filter: brightness(0) invert(1);
Note: You don't need to apply filter. I just did that to make it white. You can just upload a white Image.
Here is the output
20 REPLIES 20
Thank you Sir. Which means i cannot set same as OOB ?
I added the CSS in your widget. Please check the instance and you will see how to do it.
Ritesh
Intellective
Bringing WOW on NOW
@serviceportalpro
I did saw that and it works as expected, but only one question is, it is not aligned same as OOB icon link.
If you see the when i add the title and short descripition it is not working as OOB icon links
AAnd i am sorry to trouble you 😞
Pratiksha Kalam
Ref, Service Portal Custom Glyph
If answer is helpful please mark correct or helpful!
Pratiksha
Thank you i did gone through this but still not working
