Need help on Background Script
shaik_irfan
I am running a background script to update a field in Asset table.
I am in global scope and kept setWorkflow(false);
But i am getting a message that asset table has few business rules running on scope app which are getting triggerd. how can we stop all the BR incuding scoped applicaiton BR's
var gr = new GlideRecord('alm_asset');
gr.addEncodedQuery("active=true");
gr.setLimit(100);
while(gr.next()){
gr.setValue('state',4);
gr.setWorkflow(false);
gr.update();
I am getting below message:
Cannot disable before query business rule(s) across scope boundaries (current scope: rhino.global table scope: sn_customerservice)
17 REPLIES 17
Ashutosh,
Can you please what you mean i need to write 2 scripts 1 in global and another in scope.
If i run from scope global BR is triggering and if i write script in global scoped br are triggering
Hi Shaik,
As Ashutosh said setWorkflow(false) when called in global scope doesn't stop triggering any BR in custom scope
same script you need to run from custom scope
screenshot below; while running in background script select the scope you want
When i run in Scope i am getting
GlideSession message was modified by sanitization. [message=Access to api 'setWorkflow' from scope 'sn_customerservice' has been refused due to the api's cross-scope access policy][sanitized=Access to api 'setWorkflow' from scope 'sn_customerservice' has been refused due to the api's cross-scope access policy]
Security restricted: Access to api 'setWorkflow' from scope 'sn_customerservice' has been refused due to the api's cross-scope access policy
Evaluator: org.mozilla.javascript.EvaluatorException: GlideRecord.setTableName - empty table name (sys_script_include.d0313e05db343700752384eb0b96199a.script; line 10) EvaluatorException(JavaScript evaluation error on:
when i run in global i am getting
Hi Shaik,
If your records are getting updated then don't worry about the errors
the setWorkflow(false) is having that behavior and cannot be changed as it is from platform level
