Need help on setting hyperlink on Description field
shaik_irfan
From the workflow when we create a Catalog Task on the description field we need to set a description along with KB article hyperlink. Can anyone please help me how to do this ?
Tim Deniston
Description is a plain text field, so you cannot show a hyperlink in it. You could add an HTML description field (HR Case includes one OOB called rich_description) and replace the regular Description field on your form.
@Ankur Bawiskar is it possible to add link having filtered query in HTML format description field through script in flow designer.
Any Assistance would be helpful.!!!
Can we add the field message to the description fie
ld which has the hyper link in it
There does not appear to be a way to add links (or any HTML formatting) in field messages, though you can with info messages.
Does not work:
g_form.showFieldMsg('order','Hello <a href="https://www.google.com" target="_blank">Google</a>.','info');
g_form.showFieldMsg('order','Hello [code]<a href="https://www.google.com" target="_blank">Google</a>[/code].','info');
Works:
g_form.addInfoMessage('Hello <a href="https://www.google.com" target="_blank">Google</a>.');
Sajilal
For your requirement why not use a URL type of field instead of populating in String field.
https://community.servicenow.com/community?id=community_question&sys
Please Mark as ✅ Correct if this solves your issue and also mark ???? Helpful if it helps resolve your problem.
Saji
_id=fe030fa1dbd8dbc01dcaf3231f961992
