Need Help with Business Rule condition
geet
I have a BR where I am trying to abort the submission if user has selected Yes is approval required but has not selected one of the approval.
User should either select user approval or group approval. If none is selected it will abort action.
Here is the code. BR is acting strange as I think my condition is not correct. It is only allowing submission when both checkboxes are checked.
Please guide.
	// Add your code here
	var ApprovalRequired = current.approval_required;
	gs.info(ApprovalRequired);
	var userApproval = current.user_approval;
	var groupApproval = current.group_approval;
	if(ApprovalRequired == 'yes' && (userApproval == '' || groupApproval == '')){
			gs.addErrorMessage("Please select either User or Group Approval when Approval required is selected as Yes");
			current.setAbortAction(true);
})(current, previous);
RAMANA MURTHY G
Hello @geet ,
You need to change
this statement as below
if(approval == 'Yes' && !(userApprove == true || groupApprove == true)){
You can achieve the same without using a script, please find below screenshots
Please mark my answer helpful, if it helps you
Thank you
Please mark my answer helpful  & correct if it helps you
Thank you
G Ramana Murthy
ServiceNow Developer
soumyagupta
Please try below code:
	if(ApprovalRequired == 'yes' && ( !userApproval && !groupApproval )){
Please mark correct if it resolves your query.
Soumya
Any update on this?
