Need help with Date Validation script
nicolemccray
I need an 'OnChange' script that will check to see whether the entered 'start_date' that is less than 2 weeks from today (or whatever day they are filling out the form).   If they enter a date less than 2 weeks away, I want to display a pop up message and prevent them from submitting the form.
chirag_bagdai
Hi Nicole,
If you don't want to do ajax calls each time, you can use JavaScript validation in onChange client script and onSubmit script :
var date1 = new Date(g_form.getValue('start_date');
var date2 = new Date();
var timeDiff = Math.abs(date2.getTime() - date1.getTime());
var diffDays = Math.ceil(timeDiff / (1000 * 3600 * 24));
if(diffDays >= 14) {
      alert("Error Message");
      return false;
else
        return true;
Chirag Bagdai
34 REPLIES 34
Please validate with above screenshot.
Harshvardhan
try this one,
testing: function(){
var abc = new GlideDateTime();
abc.setValue(startDT);
abc.daysAgo(-14);
if (startDT>abc){
return false;
else{
return true;
gsetNowDateTime: function(){
return gs.nowDatetime();
Still showing errors:
Was able to get rid of most errors:
var AbstractAjaxProcessorDate = Class.create();
AbstractAjaxProcessorDate.prototype = Object.extendsObject(AbstractAjaxProcessor, {
      type: 'AbstractAjaxProcessorDate'
abc.daysAgo(-14);
if (startDT>abc){
return false;
else{
return true;
Except for this:
you need to remove line4 and as well as return in else causing the errors.
Try this one,
  var ans = true;
  abc.daysAgo(-14);
  if (startDT>abc){
  ans =false;
  return ans;
