Need help with Date Validation script
nicolemccray
I need an 'OnChange' script that will check to see whether the entered 'start_date' that is less than 2 weeks from today (or whatever day they are filling out the form).   If they enter a date less than 2 weeks away, I want to display a pop up message and prevent them from submitting the form.
chirag_bagdai
Hi Nicole,
If you don't want to do ajax calls each time, you can use JavaScript validation in onChange client script and onSubmit script :
var date1 = new Date(g_form.getValue('start_date');
var date2 = new Date();
var timeDiff = Math.abs(date2.getTime() - date1.getTime());
var diffDays = Math.ceil(timeDiff / (1000 * 3600 * 24));
if(diffDays >= 14) {
      alert("Error Message");
      return false;
else
        return true;
Chirag Bagdai
34 REPLIES 34
Very valid point Dave.
In that case, you can use Display Business Rule to get date in user's timezone and set the result in g_scratchpad as describe below :
var gdt = new GlideDateTime(gs.nowDateTime());
gdt.addDays(-14); // two week ago
  1. g_scratchpad.current_date_user_timezone = gdt.getDate().toString();
gs.nowDateTime() function will give you current date/time in user's timezone.
and your client script should work to just compare the date because we have already calculated 2 week ago date in business rule :
var date1 = new Date(g_scratchpad.current_date_user_timezone);
var date2 = new Date(g_form.getValue('start_date'));
if(date1 > date2) {
      return false;
else
        return true;
I hope this helps.
Please try and let me know in-case of any question.
Chirag
This is not working.   No message displays regardless of date selected.   Business Rule:
Client Script:
if(date1 > date1) {
g_form.clearValue('start_date');
      alert("You've entered a start date less than two weeks prior to the Start Date of the course. We cannot support all of the logistical requirements to ensure a successful delivery for this course.");
      return false;
else
        return true;
My Bad,
Can you please update the if condition "if(date1 > date1) " with if(date1 > date2)   and check if that works.
Unfortunately, no.   Still no message displayed.
Hi Nicole,
I just tried and found the issue, you need to update in display business rule with following script (line# 3)
Please try again and let me know if that works.
Chirag
