Need help with script include for a reference field
Thomas98
I have an user reference field. I have two requirements
 Users belonging to app.support group should only show up in the reference field or if the employment_type is "External)
How can I achieve this ?
Sorry. Missed the reply on changing the variable type.
Script Include should be as follows using boolean variable 'u_boolean_1'
var GetUserSys = Class.create();
GetUserSys.prototype = {
    initialize: function() {},
    GetUserSys: function() {
        var userList = [];
        var grGrMember = new GlideRecord('sys_user_grmember');
        grGrMember.addQuery('group.name', '<name of group>'); // example 'Software'
        grGrMember.query();
        while (grGrMember.next()) {
            userList.push(grGrMember.user.toString());
        var grUser = new GlideRecord('sys_user');
        grUser.addQuery('u_boolean_1', true);
        grUser.addActiveQuery();
        grUser.query();
        while (grUser.next()) {
            userList.push(grUser.sys_id.toString());
		var arrayUtil = new ArrayUtil();
		userList = arrayUtil.unique(userList);
        return 'sys_idIN' + userList.join(',');
    type: 'GetUserSys'
17 REPLIES 17
Community Alums
Could you please check the choice values defined for the field?please give the exact value.
Hi Sudeep,
This was an old configuration badly done. I have re-created the field to true/false(checkbox) "
How do I write the script if "External user" is true
Community Alums
try this
var gr1 = new GlideRecord('sys_user');
gr1.addQuery('u_boolean_1', true);
gr1.query();
Doesn't work 😞 . I only get people from the group
function GetUserSys() {
var gp = ' ';
var gr = new GlideRecord('sys_user_grmember');
gr.addQuery('group', 'a6414b0a1b92f010b6adc8486b4bcb55'); //fileter for your group
while (gr.next()) {
if (gp.length > 0) {
gp += (',' + gr.user);
gp = gr.user;
gr1.query();
while (gr.next()) {
gp += (',' + gr1.user);
gp = gr1.user;
return 'sys_idIN' + gp;
Community Alums
var gp = ' ';
while (gr.next()) {
gp = gr.user;
gr1.query();
while (gr1.next()) {
gp = gr1.user;
Please check the above.In the second while istead of gr1 it was gr earlier.
