Need some help with a GlideAggregate sum script
mitzaka
Mega Guru
Hi SNC,
Case goes like this - I have a field on the problem form (u_total), that I want to be populated with the sum of the values from the field 'u_impacted_allocation' in each related to the problem incident. Below is my script which does not sum them up currently. What am I missing?
  var gr1 = new GlideAggregate('incident');
  gr1.addQuery('problem_id', current.sys_id); //finds the outages for the incidents related to the current problem
  gr1.addAggregate('SUM','u_impacted_allocation');
  gr1.query();
  while(gr1.next()){
  var total = gr1.getAggregate('SUM','u_impacted_allocation'); //calculates the total proportional impact allocation
  current.u_total = total; //sets the calculation to the field on the problem form
  current.update();
})(current, previous);
Rovan1
I had similar issue and the group by fixed it. thanks mate.
Cory CJ Wesley
Off the top of my head - I don't think you can set values to fields inside of a GlideAggregate lookup.   So one of the things I'd do is turn this:
  while(gr1.next()){
  current.update();
into this:
  while(gr1.next()){
  current.update(); //Since this is a business Rule only use this if this is an After or Async Business Rule.
You can set inside the GlideAggregate while/if loop
Good to know.
Abhinay Erra
What is the field type of impacted allocation and total?
