Need some help with a GlideAggregate sum script
mitzaka
Mega Guru
Hi SNC,
Case goes like this - I have a field on the problem form (u_total), that I want to be populated with the sum of the values from the field 'u_impacted_allocation' in each related to the problem incident. Below is my script which does not sum them up currently. What am I missing?
  var gr1 = new GlideAggregate('incident');
  gr1.addQuery('problem_id', current.sys_id); //finds the outages for the incidents related to the current problem
  gr1.addAggregate('SUM','u_impacted_allocation');
  gr1.query();
  while(gr1.next()){
  var total = gr1.getAggregate('SUM','u_impacted_allocation'); //calculates the total proportional impact allocation
  current.u_total = total; //sets the calculation to the field on the problem form
  current.update();
})(current, previous);
mitzaka
Mega Guru
Ok, so after all of your feedback plus some experimenting on my side, I think I found the solution. Below is the code with comments:
(thanks to everyone for the ideas btw!)
  gr1.groupBy('problem_id'); //groups the incident by related problem
  gr1.addQuery('problem_id', current.sys_id); //finds the incidents related only to the current problem
  gr1.addAggregate('SUM','u_impacted_allocation'); //sums the impacted allocation values from the related incidents
  gr1.query();
  while(gr1.next()){
  var total = gr1.getAggregate('SUM','u_impacted_allocation'); //populates the impacted allocation in the problem
  current.u_impacted_allocation = total; /setting the field in the problem record to the variable carrying the sum/
  current.update();
This works like a charm, so consider this closed:)
