Need to copy email activities from incident to related problem record.
mania
Can you please anyone help me.
Thanks in Advance!
3 ACCEPTED SOLUTIONS
Hi @mania ,
I see you are triggering mails based on state as closed, resolved. So I tried to copy the work notes on related problem according to that. If it is so you can use the below code and modify as per your requirement. (Find ss attached)
	// Add your code here
	var prblm = current.problem_id;
	var state = current.getDisplayValue('state');
	var prvState = previous.getDisplayValue('state');
	var code = current.close_code;
	var notes = current.close_notes;
	var workNote = "[code]<b>Incident State    </b>[/code]" +state+' was '+prvState +'\n'+' [code]<b>Resolution Code </b>[/code] '+code+'\n'+' [code]<b>Resolution Notes </b>[/code] '+notes;
	var prblmGr = new GlideRecord('problem');
	prblmGr.addQuery('sys_id',prblm);
	prblmGr.query();
	if(prblmGr.next()){
		prblmGr.work_notes=workNote;
		prblmGr.update();
})(current, previous);
Please check and Mark Helpful and Correct if it really helps you.
Mayur Shardul
Hi @mania ,
You can add condition in code if the any of the field is empty you can ignore it.
Mayur Shardul
Hi @mania ,
This email will get captured in sys_email table from activities of incident you cant copy it directly on problem. You can use sys_email table and can get incident record from there & copy same email details on related problem record. You can utilize business rule on insert of record on sys_email and subject contains incident filter.
Mayur Shardul
13 REPLIES 13
Hi @mania ,
Once any email activity action happens on any table a record gets created in sys_history_line table for activities (in set field you can find specific record).
You can use those details and can create business rule to copy those from incident to problem.
Mayur Shardul
mania
@Mayur2109
Can you please provide BR code. It will very usefull for me.
Thanks!
Mania
Hi @mania ,
	prblmGr.query();
	if(prblmGr.next()){
		prblmGr.update();
Mayur Shardul
mania
@Mayur2109
Used your code its working but i have shared the screenshots of problem record their i can see empty resolution code and resolution notes. Is there any way to restrict this code to show only the data which is not empty.
Using the code which you provided am getting all the fields whichever is mentioned in the code, but I don't want empty values to be copied from incident activities to problem activities.
Thanks!
Mania
Hi @mania ,
Mayur Shardul
