09-20-2023 01:14 AM
Need to copy email activities from incident to related problem record.
Can you please anyone help me.
Thanks in Advance!
09-20-2023 05:27 AM
Hi @mania ,
I see you are triggering mails based on state as closed, resolved. So I tried to copy the work notes on related problem according to that. If it is so you can use the below code and modify as per your requirement. (Find ss attached)
// Add your code here
var prblm = current.problem_id;
var state = current.getDisplayValue('state');
var prvState = previous.getDisplayValue('state');
var code = current.close_code;
var notes = current.close_notes;
var workNote = "[code]<b>Incident State </b>[/code]" +state+' was '+prvState +'\n'+' [code]<b>Resolution Code </b>[/code] '+code+'\n'+' [code]<b>Resolution Notes </b>[/code] '+notes;
var prblmGr = new GlideRecord('problem');
prblmGr.addQuery('sys_id',prblm);
prblmGr.query();
if(prblmGr.next()){
prblmGr.work_notes=workNote;
prblmGr.update();
})(current, previous);
Please check and Mark Helpful and Correct if it really helps you.
Mayur Shardul
09-20-2023 06:26 AM
Hi @mania ,
You can add condition in code if the any of the field is empty you can ignore it.
Mayur Shardul
09-21-2023 03:21 AM
Hi @mania ,
This email will get captured in sys_email table from activities of incident you cant copy it directly on problem. You can use sys_email table and can get incident record from there & copy same email details on related problem record. You can utilize business rule on insert of record on sys_email and subject contains incident filter.
Mayur Shardul
09-21-2023 02:55 AM
Hi @Mayur2109 ,
Its working, but I have one doubt I want to copy emails to be received from incident activities to problem activities.
Can you please help me out this case.
Attached screenshot for your reference.
Thanks!
Mania
09-21-2023 03:21 AM
Hi @mania ,
Mayur Shardul
09-20-2023 02:02 AM
Hi @mania,
Please refer to the below link for your requirement:
https://www.servicenow.com/community/itom-forum/how-to-copy-activity-log-from-incident-to-problem/m-...
I hope this will help you solve your problem. Please mark it as Accepted and Helpful.
Thanks and Regards
Anshul
09-20-2023 02:36 AM
Follow this thread it might help you How to copy sent/received emails from incident record to a record in another table
Kindly mark correct and helpful if applicable
