11-19-2024 09:21 AM
Note: I am not a SNOW developer; I am an end-user that uses SNOW to manage incidents, tasks, and change requests.
As of yesterday, I and several members of my team have been unable to select text for copying in SNOW while using the Edge browser. Selecting text in non-SNOW tabs works fine. Selecting text in SNOW tabs in Firefox and Chrome browsers works fine. Also as of yesterday, we started seeing "Rewrite with Copilot (Alt+I)" prompts when hovering over certain elements (again, only in SNOW using Edge), and so we wonder whether the two are related. Is there a way to re-enable the "select text" functionality?
- 7,436 Views
11-21-2024 07:24 AM
Solution Fix (100% working):
This is an issue seen in latest Edge browser and is limited to the read-only fields that are of non-HTML type.
The workaround solution is:
- Download the attached XML.
- Open sys_ui_script.LIST
- Right-click on any column and select Import XML
- Then import the XML that you downloaded in step-1
That's it - the issue will be resolved.
You can refresh the page and see text highlighting when text is selected.
Important Note:
The issue will be automatically resolved when you upgrade your instance to Xanadu.
Once your instance is upgraded, you can delete the UI script imported above.
11-22-2024 07:12 AM
Thank you for your response. Where can I find sys_ui_script.LIST?
11-22-2024 09:23 AM
Just type sys_ui_script.LIST in the filter field of the ALL menu or go to ALL and type UI Scripts. It should appear in the menu under System UI.
11-22-2024 01:02 PM
I did not find either. I also searched for System under ALL, but all I got was HPE BladeSystem hits.
Is this XML intended to be imported on the client side?
11-24-2024 11:49 PM
You need to be an administrator to be able to import this type of file.
Send the link to the KB article to a ServiceNow administrator and they can import the file
04-01-2025 08:51 PM
It's working 100%. Thank you so much
