02-27-2024 10:20 AM
Hi all, I'm thinking this should be a pretty simple solution but I'm not finding it. I'm using the Active Directory v2 spoke to get the list of groups that a user is a member of. That returns an array.string output. I'd like to take that list of groups and post it as a comment on a SCTASK.
Dragging the data pill to the work notes comments results in the following. What am I doing wrong?
02-29-2024 11:18 AM
No luck on that either. While looking at that look up action, I noticed that the PowerShell step outputs all the data that it looks up in a string format, including the membership.
This gave me the idea to copy that Look Up User in AD action and remove all the Powershell attributes it looks up except for group membership, then store the Powershell output string as the membership output. That allows the membership to be displayed in string format to be used elsewhere in the flow.
It's not the prettiest output so I might go back and do some tidying up on it, but for now, it works well enough.
I'm not sure why other solutions weren't giving us the info we were looking for. I have to assume there is some bug with the AD spoke and this array. Additionally, this action should probably be OOB for this spoke. Being able to get full group membership for a user can be useful.
I want to thank you all for responding. I learned a lot from this discussion and appreciate all the feedback!
02-29-2024 06:09 AM
Hi @SanjivMeher, no luck on that. It returns the name of the object instead of the items in the array.
02-29-2024 08:07 AM
Strange. What if you try to print till user and not user.memberof?
02-29-2024 08:58 AM
Changing the script on the field to the following returns "fd-scripted" in the work notes.
var marray = fd_data._1__look_up_user.user;
return JSON.stringify(marray);
02-29-2024 10:44 AM
There is another paratermeter Full Output. Does that give like a string output? Can we use than?
02-29-2024 11:40 AM - edited 02-29-2024 11:42 AM
Hi @SanjivMeher, this is what I ended up doing to get around this problem. Here's the comment where I describe how I got that info.
I appreciate all the help with this! I now have a better understanding of dotwalking in field scripts too!
