Please help with Multirow variable set populate values
Lisa Goldman
I have been struggling to figure out how to link the two tables and get the data populated.  I hope someone can help.
I would like to populate variables in a Multirow variable set based on the selection of the part number variable.  If a part number is selected, then populate the part description, Qty and Price variables
Table: u_part_number
Columns: part_id   (Primary Key)
                 part_no
Table: u_part_detail
 Columns:  part_id (Primary Ke)
                   part_description
                   qty
                   price
Muti Row Variables:  Part No (Reference field)
                                    Part Description (Single text)
                                    Qty (dropdown)
                                    Price (dropdown)
It should replace with the new part description value.
Can you please share the screen shot of that variable configuration.
Hi @AshishKM
Here are the steps:
1. Created Part Number Table:
2. Created second table: Part Detail
3. MRVS variables:
4. Reference qualifier:
