Populating Reference Field Dropdown Dynamically Using GlideAjax on onChange Event
Deepika Mishra
Mega Guru
I have a reference field: Case Type which is showing dropdown values using a reference qualifier.
Reference Qualifier:
javascript: new global.ScriptIncludeName().functioncall(current.assignment_group.getDisplayValue());
Note: this is not a client callable script include.
This is working absolutely fine when form is loading.
I have a on change client script where the field: Case Type should populate on changing the assignment group.
As the previous one was not client callable, I made one Client callable script include and returning the choices and adding them as an option. However it doesn't seems to be working.
How can I make this work ?
Deepika Mishra
Mega Guru
I added dependent field as assignment_group and it started working. No code was required.
Deepika Mishra
Mega Guru
this is adding value but showing as empty in the dropdown:
The one marked in yellow are previous option values and new are coming as blank
Deepika Mishra
Mega Guru
This add blank values:
Deepika Mishra
Mega Guru
