Problem with setting Read Only an field form on alm_hardware table
Dario_C
Hello, I have an issue with the "Assign to" field in the alm_hardware table. I'm unable to make it Read Only after a flag is activated. I've tried creating both a Client Script, a Business Rule, and a UI policy, but the field remains editable. I can't seem to figure out why. I'm attaching the screenshots below. Thank you.
Harsh_Deep
Hello @Dario_C ,
As I can see you are using onChange client script, Please use OnLoad client script and use below script-
g_form.setMandatory('assigned_to',false);
g_form.setReadOnly('assigned_to',true);
Mark Correct if this solves your issue and also mark 👍 Helpful if you find my response worthy based on the impact.
Hi @Dario_C ,
Happy to help 🙂
Also if the response helped you could u please mark both the response as solutions accepted, as it will help other users to find the right answer.
Danish
Harsh_Deep
Hello @Dario_C ,
