Problems with API using LIKE parameter
StevenAgFirst
I am trying to access a table certificate_domain with a parameter of GET command:
GET https://environment.service-now.com/api/now/table/certificate_domain?sysparm_query=domainLIKExxxxxxx...
where xxxxx's are the hostname I am looking for.
Issuing this command in API explorer returns the correct two records. No problems.
When I execute this using the API and Visual Basic code, it returns nothing and a response code of 403. When I change the Visual Basic code to have an '=' sign instead of the 'LIKE"' in the query, it returns 1 record and all is good (response code 200). However, I need all the records because some have the xxxxxx.company.net suffix on them and I want them also.
I can't figure out what I am doing wrong. If the command works in the API Explorer, it should work in the Visual Basic program.
I appreciate anything you can tell me. Thank you in advance.
Thank you Viraj and Ankur for your responses.
I have tried multiple methods to try to get the records I am looking for, none have worked except not putting any parameters on the GET request. If I leave off all parameters, I get the entire table back and response code 200. This means that I do have authority to read the table so security is not an issue unless the LIKE command needs some security level I am not aware of.
As to encoding, I have tried:
?sysparm_query=domain=UC4PMWEB04    <- it returns the record I want
?sysparm_query=domain%3DUC4PMWEB04     <- it returns the record I want
?sysparm_query=domainLIKEUC4PMWEB04     <- Errors out
?sysparm_query=domain%20LIKE%20UC4PMWEB04     <- Errors out
I have tried these in the API Explorer and they work (have not tried the last one since the 3rd one without the spaces worked fine and returned what I wanted).
There really is nothing to encode on this statement so I don't think that is it. I also hard coded it instead of using variables to verify that there are no special characters in it and it still fails.
It acts like there is a bug in the API that just does not like the LIKE command. I have tried everything I can think of to get it to work and nothing works. I would put the code here but it uses a DLL Class that I built to do the reads. I use the code in many different programs to read data out of just about most of the CMDB tables with no issues so I know it works, just not for this table.
Thank you.
Steven
