Reference Qualifier Unique Values
05-14-2019 11:11 AM
Hello Community,
I have a Catalog item that currently has 3 Lookup Select boxes. The table they reference has 90k records. This is causing a performance issue. I need to convert at least 2 of them to Reference variables. The table that is being referenced has many safe keys to one group name. So for the end users I want them to only see the unique (distinct) Group name.
Here is the Script Include I've written, but it's not pulling back just the distinct sys_id. What am I missing?
var CyberarkGroups2 = Class.create();
CyberarkGroups2.prototype = {
initialize: function() {
getGrps: function() {
var gr = new GlideRecord('u_cyberark_data_integration1');
gr.addNotNullQuery('u_ad_group');
gr.orderBy('u_ad_group');
var filter='sys_idIN';
while (gr.next()){
filter += gr.sys_id + ','; //Gets all sys_ids for table u_cyberark_data_integration1
return filter;
type: 'CyberarkGroups2'
05-16-2019 11:23 AM
//Please try this
CyberarkGroups2: function() {
var filter
var groups_distinct = []; //array
while (gr.next()){
if(groups_distinct.toString().indexOf(gr.groupname.toString()) == -1) //please check the col name of the group. if it is not in the array add it.
groups_distinct.push(gr.groupname.toString());
} //end of while
// Please check the filter. it is not tested
var filter = 'nameIN' + groups_distinct.toString(); //will have comma seperated distinct group names
05-16-2019 01:19 PM
Hello, This took awhile to search and then sent back all the items in the column.
05-15-2019 08:57 AM
Should I using a arrayUtil.unique instead?
05-14-2019 11:23 AM
Have you called this script to the variable? You have to set the Advanced Reference Qualifier and call your script include. Please find below links which might be helpful.
Please hit correct based on impact of response.
05-14-2019 12:16 PM
