Reference Qualifier Unique Values
jmillwood
Giga Contributor
Hello Community,
I have a Catalog item that currently has 3 Lookup Select boxes. The table they reference has 90k records. This is causing a performance issue. I need to convert at least 2 of them to Reference variables. The table that is being referenced has many safe keys to one group name. So for the end users I want them to only see the unique (distinct) Group name.
Here is the Script Include I've written, but it's not pulling back just the distinct sys_id. What am I missing?
var CyberarkGroups2 = Class.create();
CyberarkGroups2.prototype = {
initialize: function() {
getGrps: function() {
var gr = new GlideRecord('u_cyberark_data_integration1');
gr.addNotNullQuery('u_ad_group');
gr.orderBy('u_ad_group');
var filter='sys_idIN';
while (gr.next()){
filter += gr.sys_id + ','; //Gets all sys_ids for table u_cyberark_data_integration1
return filter;
type: 'CyberarkGroups2'
27 REPLIES 27
so replicated your structure on my side and your script seems to be working fine.
table fields
list view of table records
script
var gr = new GlideRecord('u_application_database');
gr.addEncodedQuery('u_application=A');
var db = [];
while(gr.next()){
db.push(gr.getDisplayValue('u_database').toString());
var arrUtil = new ArrayUtil();
var dbUnique = [];
dbUnique = arrUtil.unique(db);
gs.info('Database rows (unique) == ' + dbUnique);
gs.print(dbUnique);
here is the output of your script executed in the background script executer
NOTE: all fields are string here just for testing purpose
thanks
Hammad
try
db.push(gr.u_database.name.toString());
Archisman
I had similar scenario where i would like to show column values unique in the variable.
Below are two ways achieved the same.
With passing a parameter: in my case it was dependent on "Country"
Script -
getUniqueValuesBasedOnParamters: function(country) {
        // Initializing the arrays
        var sysIdList = [];
        var nameMap = {};
        // Single GlideRecord query to fetch relevant records
        var gr = new GlideRecord('your table name');
        gr.addQuery('your parameter', country);
        gr.addQuery('active', true); // it can be gr.addActiveQuery();
        while (gr.next()) {
            var name = gr.name.toString(); //Replace it with the referenced table column.
            if (!nameMap[name]) {
                nameMap[name] = true;
                sysIdList.push(gr.sys_id.toString());
        var result = 'sys_idIN' + sysIdList.join(',');
        return result;
Advanced Qualifier - javascript: new script_include().getUniqueValuesBasedOnParamters(variable_name); //Replace or adjust as per your requirement.
Without a paramter just by referenced column name find unique:
   getUniqueValuesBasedOnReferencedFieldName: function() {
        var sysIdList = [];
        var nameMap = {};
        // GlideRecord query without country filter
        var gr = new GlideRecord('x_ubsa3_hr_custom_legal_employer');
        while (gr.next()) {
            var name = gr.getValue('referenced_coulmn_name'); //Based on the column unique will be found.
                sysIdList.push(gr.getValue('sys_id'));
        if (sysIdList.length === 0) {
            gs.info('No unique ids found.');
        return 'sys_idIN' + sysIdList.join(',');
Advanced Qualifier - javascript: new script_include().getUniqueValuesBasedOnReferencedFieldName(); //Replace or adjust as per your requirement.
Mark the solution helpful. Hope it helps.
