Reference Variable showing sysid instead of values
DUGGI
Giga Guru
I have create one reference variable.
when click on magnifier glass it showing sys_ids instead of values.
OS types.pngtable level i have updated display value true for os type field,still it showing sys_id.
Mike Allen
You can also personalize that list to make it hold whatever fields you want.   Just right-click on the header bar and choose Personalize > List Layout like other places int he system.
13 REPLIES 13
I couldn't find that personalize option in the "header" do you mean "banner", anyhow its not there neither.
Thank you Mike,
Same thing helps me
DUGGI
Giga Guru
the issue is that showing sysid in the popup view
raj-10-444
Screenshot 2024-11-04 at 11.14.10 PM.pngTry this and edit the list control, so that you can view the fields that you want
