Restricting values in record producer reference fields
umaaggarwal
Giga Guru
I have 3 fields in a record producer , user , role and group. all are reference fields . I want user to be selected as logged in user, groups which are available should be only user's group and roles which should be available are selected groups role
Hi Uma,
You can call like this
javascript:new FillGroup ().getGroupRoles(current.variables.your_group_var)
Hi Uma,
If your problem is solved, kindly mark the comment as a correct answer and helpful.
