Rule base for order guide
solanovale
I am working on the New Hire order guide, in there I have several check box variables for different systems a new hire might need. If they are checked then the RITM with the tasks for those systems will be created if it is not checked then it is not. That was created a long time ago, now the problem is I am adding a new system so I did the exact same thing added the catalog item, created the check box. The thing is that I cannot find Rule Base. I tried adding it as a related list but I cant not find it. I have looked everywhere but nothing.
Is there any other way to access it? I found (sc_cat_item_guide_items) and thought it might be it and created the conditions there but is not working. Any suggestions?
@Aditya_hublikar
Hello, thank you for your help. However as mentioned on my post, I tried to added it to the related lists already but it is not on the "available list"
