Scope AJAX Script Include and Catalog Client Script
Luis Roman1
I have the following Ajax Scripts (Include and Client) in a scope application. For some reason I am getting a browser error: There is a JavaScript error in your browser console. Can you please advise me how to addressed this problem. I am in a lost and not sure how to proceed forward.  Help appreciated.
Catalog client script:
if (newValue === 'true') {
    alert('onChangeTelecommuter_telecommuter =true= ' + newValue);
    g_form.clearValue('building');
    g_form.clearValue('column');
    g_form.clearValue('floor');
    g_form.clearValue('room_cube');
    alert('onChangeTelecommuter_telecommuter =False= ' + newValue);
        var sys_id_asset = g_form.getValue('asset');
        var ga = new GlideAjax('x_g_lme_ham_classi.getStandardFields'); //this is the script include
        ga.addParam("sysparm_name", "getFields"); //this is the function within the script include
        ga.addParam("sysparm_asset", sys_id_asset);
        ga.getXML(getResponse);
    function getResponse(response) {
        var values = response.responseXML.documentElement.getAttribute('answer').toString().split('|');
        g_form.setValue('location', values[0]);
        g_form.setValue('building', values[1]);
        g_form.setValue('floor', values[2]);
        g_form.setValue('column', values[3]);
        g_form.setValue('room_cube', values[4]);
Script Include:
var getStandardFields = Class.create();
getStandardFields.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getFields : function() {
var assetID = this.getParameter('sysparm_asset');
var standardFields = new GlideRecord('alm_asset');
standardFields.addQuery('sys_id',assetID);
 standardFields.query();
if(standardFields.next()) {
return standardFields.location.getDisplayValue()+ '|' +
standardFields.u_building.getDisplayValue()+'|' +
standardFields.u_floor.getDisplayValue()+ '|'+
standardFields.u_column.getDisplayValue()+ '|'+
standardFields.u_room_cube.getDisplayValue();
return '';
    type: 'getStandardFields'
Ankur Bawiskar
Hi @Luis Roman
try to use getXMLAnswer() in client script
        ga.getXMLAnswer(getResponse);
    var values = response.toString().split('|');
Update script include as this since you are in scope application
getStandardFields.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
return '';
are you sure there is field u_building on alm_asset?
Are you sure the field types are same i.e. u_building and building; both location fileds
If field types are same then it should work fine
