Script Help to exclude weekends
Jyoti Tripathi
Giga Guru
I have a custom True/False field, i wanted to make the field set as true when the Assignment Group for the case is empty for more than 1 business days..
Someone please help how to achieve this
13 REPLIES 13
Baala T
Mega Guru
Hi Jyoti,
Please try below code in scheduled job, value of iDay 6 and 7 are referring
  • 6 = Saturday
  • 7 = Sunday
var grCase = new GlideRecord('<TABLE_NAME>');
grCase.addEncodedQuery('active=true^assignment_group=NULL');
grCase.query();
while(grCase.next()){
	var gdtCreated = new GlideDateTime(grCase.getValue('sys_created_on'));
	var bIsWorkingDay = false;
	do {
		var iDay = gdtCreated.getDayOfWeekLocalTime();
		gdtCreated.addDaysLocalTime(1);
		if((iDay!=6) && (iDay!=7)){
			bIsWorkingDay = true;
	} while (!bIsWorkingDay);
	var gdtCurrent = new GlideDateTime();
	//gs.print(gdtCreated);
	//gs.print(gdtCurrent);
	if(gdtCreated < gdtCurrent) {
		grCase.setValue('CUSTOM_FIELD_NAME', true);
		grCase.update();
Bala
Hi @Baala T : Thanks for sharing the script, what if the case got created on weekend and group was empty (example on Saturday).. so on Tuesday(More than 1 business days) it will make the field set as true right?
Modified the script little bit. PFB
var gdtCreated = new GlideDateTime('2023-06-02 09:27:56');
gs.print('Actual Created Date & Time : ' + gdtCreated);
var bCheckCreatedInNonBusinessDays = false;
do {
    var iCreatedDay = gdtCreated.getDayOfWeekLocalTime();
    if(!bCheckCreatedInNonBusinessDays){
        //Is it created on Saturday
        if (iCreatedDay==6){
        //Check if it is falls on Sunday
        if (iCreatedDay==7){
        bCheckCreatedInNonBusinessDays = true;
        gs.print('Business Start Date & Time : ' + gdtCreated);
    //Add a Business Day
    var iBusinessDay = gdtCreated.getDayOfWeekLocalTime();
    gs.print(iBusinessDay + '<>' + gdtCreated)
    if((iBusinessDay!=6) && (iBusinessDay!=7)) {
gs.print('Business End Date & Time : ' + gdtCreated);
gs.print('Current Date & Time : ' + gdtCurrent);
@Baala T :
it is not make the Custom field to set it as true when Assignment group is empty for more than 1 business days, please help
Hope you have created as a scheduled job, What is the error that you are getting?
Let me know the Table Name and Field Name.
