Script Help !!
vidishaagarwal5
Hi Team,
I have the below scenario to be implemented help here please.
When a record from the Knowledge Base (kb_knowledge) table is deleted, you want to delete all its attachments to save space.
4 ACCEPTED SOLUTIONS
Ravi Gaurav
Hi @vidishaagarwal5
The Below Simple code will help you !!
// Table: kb_knowledge
// When: before delete
(function executeRule(current, previous) {
var attachmentGR = new GlideRecord('sys_attachment');
attachmentGR.addQuery('table_name', 'kb_knowledge');
attachmentGR.addQuery('table_sys_id', current.sys_id);
attachmentGR.query();
while (attachmentGR.next()) {
attachmentGR.deleteRecord();
})(current, previous);
If you found my response helpful, I would greatly appreciate it if you could mark it as "Accepted Solution" and "Helpful."
Your support not only benefits the community but also encourages me to continue assisting. Thank you so much!
Thanks and Regards
Ravi Gaurav | ServiceNow MVP 2025,2024 | ServiceNow Practice Lead | Solution Architect
CGI
M.Tech in Data Science & AI
 YouTube: https://www.youtube.com/@learnservicenowwithravi
 LinkedIn: https://www.linkedin.com/in/ravi-gaurav-a67542aa/
Raghav Sharma24
Giga Patron
kb_knowledge is the table for knowledge articles not knowledge base.
Try this script in After Delete Business rule on kb_knowledge table:
    var att = new GlideRecord('sys_attachment');
    att.addEncodedQuery('table_sys_id=' + current.sys_id);
    att.query();
    att.deleteMultiple();
Please mark the answer correct/helpful accordingly.
Tejas Adhalrao
Hi @vidishaagarwal5 ,
1) on  you table you can create the after business rule (delete)
 and paste this script in your business rule
    //thiss  Find all attachments linked to this Knowledge record
    //now  Delete each attachment
If my response/article helped you, please mark it as the correct answer and close the thread — this helps other readers in the community.
Tejas
🚀 ServiceNow Developer | 🏆 HackaNow Finalist | 💡 Community Contributor
📧 Email: tejas.adhalrao11@gmail.com
🔗 LinkedIn: linkedin.com/in/tejas1018
miftikhar20
@vidishaagarwal5,Once you delete an article record, no attachment will appear in the sys_attachment table, so they are removed automatically from there but might still remain part of the system. Follow this thread to remove them permanently.
https://www.servicenow.com/community/developer-forum/finding-and-deleting-orphaned-attachments/m-p/2...
Thanks & Regards,
Muhammad Iftikhar
If my response helped, please mark it as the accepted solution so others can benefit as well.
miftikhar20
Thanks & Regards,
Muhammad Iftikhar
