Script Include and On change Client script using JS methods browser issue
DPrasna
I have a script include that returns the following result exactly as shown below with comma
"Development , Production"
Client Script (not working on Portal)
		g_form.setVisible('column1',false);
		g_form.setVisible('column2',false);
		g_form.setVisible('column3',false);
	var prod = g_form.getReference('product');
	//alert(JSON.stringify(prod));
	//alert(prod.u_application_name);
	var ga = new GlideAjax('<scriptincludename>');
	ga.addParam("sysparm_name", "getCI");
	ga.addParam("sysparm_app_name", prod.u_application_name);
	ga.addParam("sysparm_sysid", newValue);
	//alert(newValue);
	//alert(newValue.getDisplayValue());
	ga.getXML(getResponse);
	function getResponse(response) {
		var res = response.responseXML.documentElement.getAttribute("answer");
		alert(res.toString());
		//var res1 = res.toString();
		if(res.includes('Development')){
			g_form.setVisible('column1',true);
			g_form.setVisible('column2',true);
		if(res.includes('Production')){
			g_form.setVisible('column3',true);
Now I need to have a client script to check the matches of the above returned results which is Dev/ Prod. I have the below script which works on Native UI but not on the Portal. It displays an error "There is a JavaScript error in your browser console
I need help to make it compatible and make it work on the Portal as expected.
@Danish Bhairag2 @Sandeep Rajput @Ankur Bawiskar @Peter Bodelier @Chuck Tomasi
11 REPLIES 11
Danish Bhairag2
Tera Sage
@DPrasna ,
Also g_form.getReference does not work in Service Portal.
Please refer this article on how to use it on portal
https://www.servicenow.com/community/developer-forum/g-form-getreference-is-not-working-in-service-p...
Danish
Ankur Bawiskar
@DPrasna
Ensure UI type is ALL and use getXMLAnswer
	ga.getXMLAnswer(function(answer){
		var res = answer;
Hi Ankur,
I tried the same using "
getXMLAnswer
However the error remains the same
Hi @DPrasna,
Do you have logging in your script include as well?
Does it complete up until the return?
As mentioned before, getReference doesn't work with a callback but I haven't seen a corrected script here.
Try this:
        g_form.setVisible('column1', false);
        g_form.setVisible('column2', false);
        g_form.setVisible('column3', false);
    var prod = g_form.getReference('product', getRef);
    function getRef(prod) {
        //alert(newValue);
        if (res.includes('Development')) {
            g_form.setVisible('column1', true);
            g_form.setVisible('column2', true);
        if (res.includes('Production')) {
            g_form.setVisible('column3', true);
Help others to find a correct solution by marking the appropriate response as accepted solution and helpful.
