Script Include help
huyjor
Hello Team
I'm trying to write a script include & client script to validate the duplicate enrollment record. If it is duplicated, it should prompt for an error when I click on submit button. This is on catalog item. I tried to test it but when i clicked on submit, nothing happened. The script seems to be ok. I'm not sure where is my mistake at. Thanks for your help
Script include below:
var SNO_AC_ku_enroll_validation = Class.create();
SNO_AC_ku_enroll_validation.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
initialize: function() {},
isAlreadyRegistered: function(studentid, courseId) {
var courseEnrollment = new GlideRecord('x_kb_ku_enrollment');
courseEnrollment.addQuery('studentid', username); //studentid field is on ku_enrollment table
courseEnrollment.addQuery('courseid', courseid); // courseid field is on ku_enrollment table
courseEnrollment.query();
return courseEnrollment.hasNext();
type: 'SNO_AC_ku_enroll_validation'
Catalog Client Script:
function onSubmit() {
var studentId = g_form.getValue('studentid');
var courseid = g_form.getValue('courseid');
var enrollment_validate = new SNO_KU_enroll_validation();
var isDuplicate = enrollment_validate.isAlreadyRegistered(studentid, courseid);
if (isDuplicate) {
alert("You are already enrolled in this course");
return false;
return true;
Change line 7 to
		gr.addEncodedQuery("student_id=" + studentid + "^courseid=" + courseid);
I'm able to fix it error line 7. But when I clicked on the submit button. It still not giving me the alert. If the value of the student_id & courseid fields already are existing the table. It should give the alert for duplicate record.
James Chun
Hey @huyjor,
Try the following, if it still doesn't work, I recommend adding more logs and doing some debugging:
Script Include:
var SNO_AC_ku_duplicate_enrollment = Class.create();
SNO_AC_ku_duplicate_enrollment.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
    checkPrerequisite: function() {
		gs.info('[Testing Client Script] Starting of checkPrerequisite');
        var studentid = this.getParameter('sysparm_studentid');
		gs.info('[Testing Client Script] studentid is ' + studentid);
        var courseid = this.getParameter('sysparm_courseid');
		gs.info('[Testing Client Script] courseid is ' + courseid);
        courseEnrollment.addQuery('studentid', studentid); //studentid field is on ku_enrollment table
		gs.info('[Testing Client Script] query is ' + courseEnrollment.getEncodedQuery());
		gs.info('[Testing Client Script] has next is ' + courseEnrollment.hasNext());
    type: 'SNO_AC_ku_duplicate_enrollment'
Client Script:
    var dupEnroll = new GlideAjax('SNO_AC_ku_duplicate_enrollment'); //typo here
    dupEnroll.addParam('sysparm_name', 'checkPrerequisite');
    dupEnroll.addParam('sysparm_studentid', g_form.getValue('studentid'));
    dupEnroll.addParam('sysparm_studentid', g_form.getValue('courseid'));
    dupEnroll.getXMLAnswer(getResponse);
    function getResponse(response) {
        if(answer == 'true' || answer == true)
			alert('True returned');
		}else
			alert('False returned');
Another thing to note is that you won't be able to prevent submission using AJAX.
There are heaps of workarounds for these (e.g. creating a hidden variable and setting it true/false via onChange) or also this - https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB0783579
Cheers
Sohithanjan G
Hi @huyjor ,
  1. onSubmit Ajax call will not prevent Form submission
  2. Try to restrict form submisssion either from client side (client script) or server side (before BR)
Please mark as Accepted Solution if this solves your query and HIT Helpful if you find my answer helped you. This will help other community mates too..:)
