Script Include not working in reference qualifier
08-02-2023 12:45 AM
08-02-2023 01:28 AM
Now, i am using this
08-02-2023 01:57 AM - edited 08-02-2023 01:59 AM
No it's not working because an advanced reference qualifier expects some input to be used to filter records.
Think of it as you want it to get records in some form of encoded query.
So the script include is working fine, but the calling source (reference qualifier) expects some string result that can be used in a query.
Something like
active=true^installed=1 etc
or perhaps something like
sys_idINa,b,c,d,e,f
So the initial issue is in your statement "I am trying to update the field with a Number using reference qualifier..."
Reference qualifiers aren't meant to be used like that. Updating records and such.
Please elaborate more on your requirement, before we dig into possible solutions.
08-02-2023 03:16 AM - edited 08-02-2023 03:17 AM
I wanted script include to return a Number from table - sn_risk_advanced_risk_assessment_instance like RASMT00100057 and it will populate in the field where I have defined reference qualifier on table - sn_risk_advanced_risk_assessment_instance.
08-02-2023 12:52 AM
Hi @aagman4,
What is your exact requirements?
Note: In reference qualifiers, Script Include restricts records, not updates them.
If my response helps to solve your issue. Kindly mark it as helpful & correct. It will be helpful for future readers.
Sagar Pagar
08-02-2023 12:58 AM
I wanted to filter a record from a table and update the number of that record in a field in a form. Can it be done?
